DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Blanking off pipes for a radiator no longer needed
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
RainbowWrighty
from United Kingdom
PostPosted: Sat Oct 24, 2009 8:18 am Reply with quote
The radiator in our kitchen is no longer needed and I need to do something with the pipes.
After draining the central heating system, I was planning to cut the left hand pipe (shown below) with a pipe cutter (chipping away the wall plaster if necessary) and fitting a push on end cap. Re-plastering and skirting would then be fitted.
On the right hand pipe, I was going to remove the push on joint but I still want to have the drainage tap, so was going to re-position that at the 90 deg joint. I was planning to box this in afterwards (removable for future system drains)
Is this the way it should be done or can anyone advise a better solution to doing away with the old pipes?
Thanks in advance guys,
Ade
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2772 times
PostPosted: Sat Oct 24, 2009 8:29 am Reply with quote
Joints that are not accessible for instpection should only be soldered.
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 424 times
PostPosted: Sat Oct 24, 2009 9:16 am Reply with quote
Do the pipes go right through the wall? If so can you cut them the other side.
I would use a solder cap if plastering over it. If you're not happy about soldering could you extend your proposed boxing to cover both pipes.
Back to top
 Alert Moderators
RainbowWrighty
from United Kingdom
PostPosted: Sun Oct 25, 2009 8:34 pm Reply with quote
bengasman - thanks, you confirmed a niggling suspicion I had about not soldering hidden joints...especially as the joint will be near a floor with electric underfloor heating!
Mick - the pipes do indeed go through the wall to another radiator (in the lounge).
I've decided to replace the radiator on the other side of the wall shown in the pics and at the same time, fit a drainage tap that side and remove the redundant pipe work shown altogether.
Thanks for your help guys.
Ade
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Odd Size Blanking Plug Needed 17 1640 Mon Aug 27, 2007 8:38 pm
Radiator blanking plugs - standard size&thread? 2 100 Mon Dec 22, 2014 5:25 pm
Leak at blanking plug Stelrad Radiator 4 120 Fri Aug 19, 2011 6:26 pm
blanking off a waste pipe 6 120 Fri Jan 20, 2012 8:56 pm
Small 45 degree blanking plate on drain - 50+ years old 2 80 Fri Jun 28, 2013 3:08 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
