Joined: 16 Feb 2007 Posts: 7599 Location: West Midlands, United Kingdom Thanked: 129 times
Posted: Tue Oct 27, 2009 11:37 pm Post Subject:
replacing bricks mid wall?
knocked some plaster off and found a bodge of half bricks and plaster filling in a hole that's ended up as about 4 bricks.. ( 1 over 2 over 1 ) to fill back in..
how do you do this?
how do I get mortar into the joints?
obviously I can get it on the top of the course below, but how at the sides and on top of the top brick?
__________________ If you make everything idiot proof, evolution will just make a better idiot.
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
Posted: Tue Oct 27, 2009 11:48 pm Post Subject:
fairly dry mix, on back of trowel line up with joint, push in with small trowel/bucket handle . For vertical joints ( perps) similar but make sausage in gloved hand ( to keep cement off skin) and because everyone wears latex gloves now
Joined: 13 Sep 2008 Posts: 625 Location: Somerset, United Kingdom Thanked: 7 times
Posted: Wed Oct 28, 2009 12:09 am Post Subject:
When you are putting the closer brick in, butter up the sides and top of the hole and angle it slightly. Butter up the brick and angle the mortar the other way. Push the brick gently in and then push in more if required with a tuck jointer if you have one, or a pointing trowel.
Joined: 03 Sep 2006 Posts: 5717 Location: Birmingham, United Kingdom Thanked: 52 times
Posted: Wed Oct 28, 2009 12:11 am Post Subject:
As this is inside you would drop a lump of mortar for the bed joint, butter the bricks and slide them in, and for any other open joints just flick a dollop of mortar in off the trowel.
It's not outside the Town Hall holding 50 storeys up, its a hole which is going to be plastered.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
