DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vaillant Boiler temperature settings
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Henryv
from United Kingdom
PostPosted: Sat Oct 31, 2009 9:12 am Reply with quote
Warm greetings,
I have a Vaillant ecoTEC plus 630 condensing boiler and need guidance for a winter temperture setting for the central heating.
I have seen general comments on the net like 82C Winter & 70c Summer. Not sure if they apply to my type of boiler?
Seem high?
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2181 times
PostPosted: Sat Oct 31, 2009 9:25 am Reply with quote
The lower your boiler setting, the more efficient your boiler runs. If you want the lowest gasbill possible, set the boiler at 55, and go up in small steps if you find it takes too long to heat the house.
In theory, a lower boiler setting also means a bit less wear and tear on the boiler.
Back to top
 Alert Moderators
Henryv
from United Kingdom
PostPosted: Sat Oct 31, 2009 10:25 am Reply with quote
Thank you- I will set to 55C.
It was set at 45C and reading as 41C approx', but the far radiators do not get hot enough in the cold weather.
Henry.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2181 times
PostPosted: Sat Oct 31, 2009 10:30 am Reply with quote
Your system is not balanced properly; all radiators that are on, should be roughly the same temperature regardless of how many are on and how far they are from the boiler.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2529 times
PostPosted: Sat Oct 31, 2009 11:46 am Reply with quote
You dont mention hot water!
If the boiler is heating hot water then it will need to be set at least 5-6° above the target hot water temperature which is ideally set to 55° making the boiler need to be at least 60°.
Of course it could be that you have a control which already raises the boiler temperature just for hot water.
Tony
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2181 times
PostPosted: Sat Oct 31, 2009 11:53 am Reply with quote
Do you have vented or unvented cylinder?
Back to top
 Alert Moderators
Henryv
from United Kingdom
PostPosted: Sat Oct 31, 2009 3:03 pm Reply with quote
The water for the hot taps has an indirect heating tank and a motorised valve in the loft.
I am not sure what the max' temp for this is set at.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2181 times
PostPosted: Sat Oct 31, 2009 7:07 pm Reply with quote
Is that vented or unvented?
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 431 times
PostPosted: Sat Oct 31, 2009 7:47 pm Reply with quote
are you using a VR65 or a seperate wiring center? as only with the VR65 will the water temperature guage on boiler work. with 3rd party controls the heating control will do both heating and hot water
Back to top
 Alert Moderators
Henryv
from United Kingdom
PostPosted: Sat Oct 31, 2009 10:16 pm Reply with quote
Vented.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2529 times
PostPosted: Sat Oct 31, 2009 11:04 pm Reply with quote
And the controls?
Tony
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 431 times
PostPosted: Sat Oct 31, 2009 11:19 pm Reply with quote
Back to top
 Alert Moderators
Henryv
from United Kingdom
PostPosted: Sat Oct 31, 2009 11:39 pm Reply with quote
I do not know any more.
I will need to consult the installer.
Henry.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2529 times
PostPosted: Sun Nov 01, 2009 12:09 am Reply with quote
In the meantime setting the heat control to about 65° C will be a good compromise.
Tony
Back to top
 Alert Moderators
Henryv
from United Kingdom
PostPosted: Sun Nov 01, 2009 12:21 am Reply with quote
Thanks Tony,
I have done that and I am balancing the rads!
It is already much better.
Thanks to all.
Henry.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Programmable thermostat - two temperature settings 8 660 Wed Nov 04, 2009 3:26 pm
Temperature Settings 2 360 Tue Dec 08, 2009 8:58 pm
Vaillant vrt392f Circulation Pump Settings 6 60 Sun Dec 18, 2011 11:16 am
Vaillant "D" Settings help 20 340 Thu Dec 06, 2012 11:00 pm
Settings for Combi boiler programmes - constant or not?? 12 260 Tue Jun 07, 2011 9:47 pm
DIYnot
