cold radiators
23 Jan 2005
hi the problem we are having is that the radiators in each room are cold from the bottom half bit hot on the top half.i have tried bleeding them bit there is no air only water comes out.any suggestions please help.
They're either full of sludge, or the flow rate is much too low. See if you can turn the pump up.
If not try closing most of the rads to see if the remaining ones get better. If they do, you may need a new pump. Try bleeding the pump first by unscrewing the big screw in the middle, though it's unlikely to be that if you haven't had rads off to let air in.
