DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hole in the wall!
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
Pudz
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 23, 2005 2:10 pm    Post Subject:
Hole in the wall!
Reply with quote Thanks
Ok I've never done any DIY in my life, but as my parents are too lazy to finish off the decorating in the toilet, I'm going to have to do it icon_redface.gif
I don't even know where to start so I've just taken a picture, I'm looking to fill the gap in completely as if it wasn't even there in the first place, please could anyone tell me how I can fix this mess..
http://www.pudz.pwp.blueyonder.co.uk/mess.jpg
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
TexMex
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 5:20 am    Post Subject:
Preparation:
First of all go out and get yourself:
1 bag of readymixed mortar
A small bottle of plasticiser
about 4 lightweight building blocks
a small bag of finish plaster (make sure it's suitable for backgrounds of high suction, something like "Hardwall" would be ideal)
Next, if it's not going to cause too much inconvenience, I'd remove that cistern until the job is done.
Hack off the surface plaster around the hole to form a border (about 2" wide). Don't worry about making this neat. If it has an irregular shaped edge, it is actually easier to blend in with the new plaster.
Using a saw, Hammer, bolster, chissel, or whatever takes your fancy, Cut a piece of building block to fit into the gap over the soil pipe. (allow for about 10-15mm of mortar all around it, but you don't have to be too acurate). This wants to have a flat top to it, (that will be level with the flat top, to it's right).
Soak the wall all around the hole, Mix up some mortar (adding a dash of plasticiser to the water before mixing).
Butter up the bit of block you have just cut, and put it into position. Note, the front face of this should be flush with the front of the blockwork (ie, about 15mm behind the face of the finished plaster), NOT the front of the wall.
Cut up and lay some more bits of block to fill in beside this first piece, and form a nice level top face.
Cut and lay some more (larger pieces this time) to lay on top, and fill the hole completely.
Rake out the joints so that they are set back about half an inch from the face of the blockwork, and leave overnight.
Wet the wall thoroughly and mix up some more mortar.
Spread the mortar on the wall and get it as flat as you can but about 3mm shy of the final face of the wall.
Make a 2 sets of score marks in the render using the corner of your trowel. One set at 45 degrees to the right and another at 45 degrees to the left. This should give you a nice diamond pattern to act as a key for the plaster.
Leave overnight.
Wet the wall again and mix up some plaster. Spread the plaster on the wall right across and beyond the edge of the hole. Scrape off the excess with a straight edge.
Roughly smooth over and leave untill it feels quite firm to the touch.
Smooth over again, give a light spray of water and polish off with your trowel.
Leave about a week and paint the whole wall.
Back to top
 Alert Moderators
swelec
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 6:21 am    Post Subject:
Why tell him what to do when you seem to have done the job already?
icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Will you paint it for him next week
One of the best replies i've seen on this forum
One gold star to you
Back to top
 Alert Moderators
Pudz
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 7:07 am    Post Subject:
I can't thank you enough TexMex thats better than I could have hoped for, thanks alot mate =)
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jan 24, 2005 9:39 am    Post Subject:
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Mon Jan 24, 2005 11:36 am    Post Subject:
Eddie M wrote:
You would've thought TexMex completed the job, just not good enough. icon_lol.gif icon_wink.gif
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Mon Jan 24, 2005 6:34 pm    Post Subject:
nah hes missed a bit around the pipes!
__________________
have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Back to top
 Alert Moderators
A C Electrical
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 04, 2005 9:59 pm    Post Subject:
What was at the other side.... lol
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
When you drill a hole through an outside wall . . . 10 600 Sat May 12, 2007 2:13 pm
Coring a long long hole in wall for drain 6 560 Sun Aug 19, 2007 10:51 pm
Hole in Internal Breeze block wall - How to fill? 6 880 Tue Sep 11, 2007 10:24 am
large hole in stud wall 4 360 Tue Apr 03, 2007 10:51 am
Cutting a hole in the wall for a door 2 580 Fri Jan 05, 2007 9:43 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
