I am trying to replace an existing double gang switch with a dimmer switch. The switch operates 2 seperate lights in the kitchen / dining room, and there is one other seperate switch (single) that operates the kitchen as well.
However the 2 switches ie old and new, are completely different inside, and before i start messing I'd appreciate some advice.
The existing switch is wired in 2 halves as follows half one has 2 brown joined into connection labelled L at the top with a single brown wire into a connection labelled 1 at the bottom (the other marked 2 is empty), the other half has a single brown wire into connection 'L' with connection '1' having a grey wire and '2' having a black wire - there are also 3 earth cables (green and yellow) into an earth block.
The new switch has again 2 distinct halves but either way up ie all the connectors on one at the top, and the same on the other but on the bottom - the cables are labelled L1 , L2 and a symbal with I assume a current flow wave and an arrow crossing it.
Why they can't keep things the same I don't know, but any help would be really appreciated
