Hi, I was hoping someone can give me some advice. I have a normal central heating system, two tanks in the loft, a hot water cylinder. Motorised valve etc.
The house is only 10 years old, central heating plumbed using 10mm plastic barrier piping (I hope!!) I am the second owner of the house.
Problem: One of the bathroom radiators kept getting air in it. So I kept bleeding it. Got fed up with this so got some plumbers round to see what the problem might be.
All mentioned a power flush and fitting an AERJEC.
Had this done. No air in system, but the water in the small central heating tank in the loft
Is always kind of brown/red. Never clear.
I removed all the water from the tank, cleaned it, left a container under the vent pipe to see if it was pumping over, it is not. Left the tank bone dry, to say what was happening.
Somehow there appears to be small amount of water coming back into the tank from the “outlet” of the tank. Central heating pump speed set to three.
Now I have had some plumbers around again. One guy says I should seal the system, put and pressure vessel in and fit a Maga Clean Filter in. But mentioned that the pressure will drop a couple of times in the years and should be top up.
Well if the system is sealed and there are no leaks, way should the system need topping up??
The other guy thinks I have some non barrier pipe used which is introducing oxygen into the central heating water from somewhere after the heating as reached 65degrees C. And to live with the problem and to flush out the central heating system every couple of years. Other than that, to check all the central heating pipes or to re-plumb the whole central heating system again
Sorry about the long explanation but can someone help me out. I have already spent nearly £900 pounds.
