The plaster cracked around my wood burner, so I was going to remove the old plaster and line it with 9mm masterboard.
My question is, is masterboard a finished product that can be fitted then painted.
masterboard is usually incorporated into the structure and acts as a fireproof lining but if you don't mind the look of it then just paint over it.
In non flammable paint of course
Gypsum plaster is only good up to around 50 degrees C; permanent exposure to much above that & it will crack & blow, as you’ve found out . Masterboard will work but will look a bit rough & ready as a finish, if you want a more conventional "plaster" look, use a heat resistant plaster over heat resistant screed base; http://shop.vitcas.com/vitcas-heat-resistant-plaster-16-p.asp
or you can use a sand/cement/lime render mix as a base which will work just as well.
You may think it’s relevant but this this thread is 2 years old, please post your own thread; it’s better for everyone but if necessary link your thread to the original.
--------------------------------00000000000000000----------------------------
Please familiarise yourself with the forum rules and enjoy the site!
6) Do not hi-jack posts. Hi-jacking is adding your query to somebody else's thread.
