DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Radiators cold at bottom
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
ojnet
from United Kingdom
PostPosted: Wed Jan 26, 2005 10:42 pm Reply with quote
ok, I know this has been kinda covered before but I would appreciate clarification, my system is now 12 years old I have had a new Combi boiler fitted about two years ago, but the system was not power flushed when installed.
This weekend I will be looking at several radiators that are getting hot at the top but remain cold at the bottom, would I be correct in assuming this problem will be caused by sludge ?
as I only run about 50% of my radiators can I forget about the balancing issue ? or should I keep that in mind?
Yours a total radiator flushing novice
Back to top
 Alert Moderators
htgeng
from United Kingdom
Thanked: 94 times
PostPosted: Wed Jan 26, 2005 11:12 pm Reply with quote
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
open the locksheilds another 1/4 turn see if it helps icon_smile.gif
Back to top
 Alert Moderators
ojnet
from United Kingdom
PostPosted: Fri Jan 28, 2005 8:32 pm Reply with quote
Tried the Quarter turn but still same
Back to top
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Sat Jan 29, 2005 4:30 am Reply with quote
Back to top
 Alert Moderators
KWB
from Ireland
PostPosted: Tue Feb 01, 2005 6:41 pm Reply with quote
Any luck with this problem? I have same but my system is only 2 1/2 yrs old so this can not be sludge. I got a plumber in and he said this was normal which I know is crap because they were fine just before Xmas. I figure there may not be enough water in the network but don't know how to fix this?
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 2 times
PostPosted: Tue Feb 01, 2005 7:30 pm Reply with quote
KWB wrote:
Any luck with this problem? I have same but my system is only 2 1/2 yrs old so this can not be sludge. I got a plumber in and he said this was normal which I know is rubbish because they were fine just before Xmas. I figure there may not be enough water in the network but don't know how to fix this?
check the pressure gauge
Back to top
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Tue Feb 01, 2005 8:29 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Radiators cold at bottom/ or not working at all 6 2040 Thu Dec 20, 2007 2:28 pm
radiators cold at the bottom and hot at the top. 3 2060 Mon Nov 27, 2006 10:04 pm
Radiators cold at the bottom. 16 360 Sun Nov 18, 2012 8:44 pm
cold radiators at the bottom 4 660 Sat Oct 24, 2009 10:02 pm
Radiators - Hot at the top, cold at the bottom 5 120 Mon Oct 08, 2012 7:13 pm
DIYnot
