DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Excel VBA help
Post new topic   Reply to topic    DIYnot.com Forum Index > Software
  View previous topic :: View next topic
Author Message
amatureleccy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 27, 2005 9:19 pm    Post Subject:
Excel VBA help
Reply with quote Thanks
I recorded a macro of the creation of a pivot table.
The bit of code that does the business is shown below.
ActiveWorkbook.PivotCaches.Add(SourceType:=xlDatabase, SourceData:="'ALL'!R1C2:R1655C7").CreatePivotTable TableDestination:="", _
TableName:="PivotTable1"
My problem is that the SourceData uses fixed cell addresses R1C2 and R1655C7.
I regularly add rows to the data and want rebuild the pivot table. I therefore want to have the code use the values from a variable containing the address of the last cell.
I don't know how to write the SourceData bit so that it uses the variables.
Any help would be greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
TexMex
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 28, 2005 2:35 am    Post Subject:
I would suggest that you choose the last entry on column 1 of your source data sheet to indicate the length of your table. You could then insert this into the rest of the hard coded range. So something like the following:
'Declare variables
Dim TableLength As String
Dim FullRange As String
'This next line returns the last row number of column 1
TableLength = Worksheets("'ALL'").Rows(1).End(xlDown).Row
'This line inserts the Row found above into the full Range that you want
FullRange = "'ALL'!R1C2:R" & TableLength & "C7"
'This line is a copy of your original line BUT
'Substitutes the variable "FullRange" for your original hard coding
ActiveWorkbook.PivotCaches.Add(SourceType:=xlDatabase, SourceData:=FullRange).CreatePivotTable TableDestination:="", _
Something that worries me, however, is that you appear to have appostrophies in the name of your worksheet (ie 'ALL' ) My version of excell (2000) doesn't allow this.
Back to top
 Alert Moderators
pipme
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 28, 2005 3:32 am    Post Subject:
Ever tried playing with 'array functions' ?
the function below effectively 'looks' down col from L4 to L1000, if the word 'pet' is found then the corresponding value in col M is added, else if not 'pet' then '0' is added, to form a sum of all 'pet' values ... I think 'pet' could be a fixed ref cell hence have a variable 'word'.
{ SUM ( IF ( (L4:L1000 ) = "pet" , ( M4:M1000 ) , 0 ) ) }
The 'curly brackets', denoting array function are inserted by <ctrl> <Enter> to complete the entry and insert into cell.
Not an answer to the problem set, but worth a thought when designing a spreadsheet.
P
__________________
Beware of little expenses; a small leak will sink a great ship. (Ben Franklin)
Back to top
 Alert Moderators
amatureleccy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 31, 2005 10:28 pm    Post Subject:
Cheers TexMex you've carcked it for me.
And that array stuff - why didn't I think of that - more for me play with.
Cheers to you both.
Back to top
 Alert Moderators
pipme
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 01, 2005 5:50 am    Post Subject:
Excel is a fab program ..... Loads of M$ help and links to be googled for the huge amount of freeby stuff which exists.
Drop in here :-
http://j-walk.com/ss/excel/index.htm
Follow the 'links'.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Software All times are GMT
Page 1 of 1
Jump to:
Excel: Lookup problem 6 640 Tue May 06, 2008 10:06 am
EXCEL 4 500 Thu Dec 27, 2007 12:26 pm
Undo read only excel file 6 580 Mon Nov 12, 2007 1:31 pm
Help with Excel macro please 2 420 Tue Nov 06, 2007 9:50 pm
MS Excel question 14 660 Sat May 31, 2008 9:43 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
