| Author |
Message |
Andy165
Joined: 09 Nov 2007 Posts: 514 Location: Merseyside, United Kingdom Thanked: 13 times
Posted: Thu Nov 19, 2009 9:12 pm |
Changed a kitchen mixer tap (washer type) to customers new ceramic disc mixer tap and am now getting water hammer in cold mains supply pipe. Have installed "Hammer Arrester" close to mixer tap which has helped a little. Also put on a Pressure Reducing Valve but it made no difference. Existing pipes buried in kitchen wall behind units, stop tap in street quarter turn type. Any sugestions for remedy before customer drives me nuts. Have looked at other threads on water hammer but they offer no extra advice/ solutions. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Elkato531
Joined: 22 Jul 2009 Posts: 271 Location: Sussex, United Kingdom Thanked: 34 times
Posted: Thu Nov 19, 2009 9:38 pm |
If, as you say you've already fitted a hammer arrester the problem is probably due to the pipework being insufficently clipped where you can't get to it.
I assume that you've fitted the tap the customer wanted and done what you can to alleviate the hammer problem. The fault is not with the work you've done but with the pipework. Unless they want you to start pulling apart their kitchen, they may just have to learn to turn the tap off slowly. |
| Back to top |
compheat
Joined: 22 Nov 2005 Posts: 1582 Location: Lancashire, United Kingdom Thanked: 247 times
Posted: Thu Nov 19, 2009 9:46 pm |
Try turning down internal stop tap.
The pressure in my own house is approx 6bar and when stop tap is on full i get water hammer but if its turned down slightly its ok. |
| Back to top |
Andy165
Posted: Fri Nov 20, 2009 12:03 am |
Thanks for the replies. The internal stop top does not control the cold main pipe to the kitchen sink. The lead pipe branches off under the solid kitchen floor before the stop tap, and then somewhere behind the units joins onto copper.The kitchen tap cold feed has to be isolated by the roadside stop tap (quarter turn). Odd I know, but the house is about 70 years old. |
| Back to top |
Whitespirit66
Joined: 15 Dec 2007 Posts: 4796 Location: Bristol, United Kingdom Thanked: 404 times
Posted: Fri Nov 20, 2009 12:10 am |
I had this problem after changing a customer's tap once. Turned out it was the washer in the stop tap that had broken up. The metal stop tap jumper was moving and banging when a tap was turned on or off.
The stop tap washer must have broken up when I used it to turn the water off. Just a thought. |
| Back to top |
JayJay1978
Joined: 19 Feb 2009 Posts: 312 Location: Bradford, United Kingdom Thanked: 24 times
Posted: Fri Nov 20, 2009 12:47 pm |
| Back to top |
Andy165
| Back to top |
