I have a Potterton system boiler (Performa 12e) which is controlled by a Myson timer and a Myson thermostat (MRT1).
I always have my heating set at 20c and let it run 24hrs a day. I have came home on two occassions now to find that the house is roasting and that the radiators are on full.
I assumed that it must be a fault with the MRT1 since when I turn the control knob both ways the heating switches off again, almost as if it has just stuck a bit!
The thermostat seems to be clicking on and off quite nicely though and before I go and replace it I was wondering if it could be a problem with the timer electronics not picking up the signal from the stat or if it might even be a problem with the boiler electronics or a micro switch or something.
What would your initial thoughts be?
Many thanks
Steve.
Many thanks
Steve.
