DIYnot
Local | Network
   DIYnot > Forums
Local | Network
One for the Baxi boys.......
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
HarrogateGas
from United Kingdom
Thanked: 8 times
PostPosted: Wed Dec 02, 2009 7:46 pm Reply with quote
Platinum 33HE with intermittant E131 code.
Code not in the destructions.
It is under Warrenty ( I installed new system about 3 weeks ago) but the house is currently empty and being renovated so someone is not always there to let anyone in. I will get heat team out soon but just curious as to what E131 is.
Installed over 90 Duotec/Platinums and this is the first issue ive come across in 18 months.
Cheers
Back to top
 Alert Moderators
Newcastle88
from United Kingdom
Thanked: 4 times
PostPosted: Wed Dec 02, 2009 9:11 pm Reply with quote
I have had this once and it turned out to be a fault with the power supply coming into the boiler. Although when it did happen to me i was also getting other fault codes too
Back to top
 Alert Moderators
rojaca
from United Kingdom
Thanked: 80 times
PostPosted: Wed Dec 02, 2009 9:20 pm Reply with quote
never seen this. If it does relate to electrical supply may be worthwhile wiring a flying lead and linking out external controls. Still check flying lead for correct polarity etc
Back to top
 Alert Moderators
Baxi-Remeha
from United Kingdom
Thanked: 88 times
PostPosted: Wed Dec 02, 2009 9:26 pm Reply with quote
e131 is a fault code that means loss of power to appliance, can be caused intermitantly after e125 lockout, or by powering off from fused spur or power cuts.
hope this helps.
can also be caused by a software issue on pcb...
Back to top
 Alert Moderators
bureaucrazy
from United Kingdom
PostPosted: Mon Feb 13, 2012 7:15 pm Reply with quote
hope this helps.
Hi, I have just had this same problem. I switched my baxi platinum boiler off on the panel because I needed to turn off the electricity supply to the house. The boiler had been firing the central heating before I switched it off. Before actually turning the off switch, I turned down the temperature dials to the lowest setting and the flame light went out. I then waited about 60 seconds for the heat to get out of the system before turning the dial to off. When I switched it back on 2 hours later, I got E125. I switched it off and on again and got E131. Have I destroyed the boiler? How long do you need to wait after the flame is out to power down safely?
What do I do to fix this? Does the BAXI platinum combi HE have a reset button? if so where?
Could it be that the condense did not have time to drain before I powered down?
It seems crazy that powering off can break a boiler. Please help..Thanks
Back to top
 Alert Moderators
bureaucrazy
from United Kingdom
PostPosted: Mon Feb 13, 2012 8:47 pm Reply with quote
Answer
The problem was that I didn't let it cool down long enough before disconnecting the power. The residual heat in the heat exchanger caused the water that was no longer being pumped to exceed the maximum permitted temperature and trigger the fault condition. E125 means water temp exceeded twice in 2 hours. E131 occurs when you try to operate the boiler in E125 condition.
The reset is done by holding the power dial anti clockwise for 5 seconds and then let go. This has brought everything back to life icon_smile.gif
Perhaps BAXI should design their boilers with a safety shutdown so that if you turn it off from the front panel some LEDs flash while it takes a few minutes to expel excess heat before disconnecting the mains power (much like windows shut down). Or at least it should warn you in the instruction not to suddenly turn off the power without letting things cool down first.
Call me cynical but maybe they get more call outs with it designed the way it is?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
1 for the baxi boys 6 620 Thu Nov 29, 2007 12:07 am
One for the Baxi boys. 11 680 Wed Oct 18, 2006 8:04 pm
One for the BAxi Boys 8 960 Sat Apr 21, 2007 9:01 pm
Bathroom boys - recognise shower waste?? 2 420 Tue Mar 04, 2008 6:02 pm
One For The Oil Boys...... 4 200 Tue Dec 07, 2010 7:06 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
