DIYnot
Local | Network
   DIYnot > Forums
Local | Network
keston (ugh) fault, b26 but open vented
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
exbg1
from United Kingdom
Thanked: 1 time
PostPosted: Sun Dec 13, 2009 6:00 pm Reply with quote
icon_question.gif serviced a c40 keston friday. usual warped electrode ! all working ok as i finished, customer phoned me up today & said boiler stopped working & shows a B26 fault. this is low water pressure fault. as this is an open vented system, how can that happen,
Back to top
 Alert Moderators
Keston
from United Kingdom
Thanked: 5 times
PostPosted: Wed Feb 03, 2010 9:01 am Reply with quote
Link out the water pressure switch, if it fires up then replace it.
simple.
Back to top
The following user says thank you to Keston for this useful post:
exbg1 (18 Feb 2010)
 Alert Moderators
HenryE
from United Kingdom
PostPosted: Sat Jan 01, 2011 2:56 pm Reply with quote
I have a C55 with a similar problem. How do I link out the water pressure switch?
H
simple.
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 422 times
PostPosted: Sat Jan 01, 2011 4:44 pm Reply with quote
You don't, this is classed a safety device so you need a RGI, who should be able to test it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Keston C25 (open) problem not matched in diagnostics 28 4420 Sun Aug 13, 2006 2:09 am
KESTON C25 IGNITION FAULT HELP URGENT 3 400 Fri Feb 27, 2009 12:06 pm
Keston 25 fault symptom 13 620 Thu Jan 26, 2006 10:58 pm
keston c55 fault code ? 21 5020 Sun Jan 18, 2009 4:55 pm
Keston Celcius 25 HW fault causing vibrations 12 340 Fri Aug 05, 2011 1:14 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
