DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Minimum landing size
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Author Message
a1topdog
from United Kingdom
Thanked: 2 times
PostPosted: Thu Feb 03, 2005 9:21 pm Reply with quote
I am having a new stair case fitted. It is a straight flight. At the top of the stairs will be a door to the left.
The question is what is the minimum size allowable between the top of the stair and the door?
I did find an article that said 400mm if the door opened onto the landing , but mine will open into the room.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Fri Feb 04, 2005 5:54 am Reply with quote
Might be an idea to give BCO who can tell you over the phone because it can be confusing as they will need to know the floor area of the room as well !
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 30 times
PostPosted: Fri Feb 04, 2005 8:18 am Reply with quote
Don't know where 400mm comes from but for a single room loft conversion the landing needs to be the width of the stairs square ie 700mm wide staircase landing 700x700 although if space is tight and you speak nicely to BCO he may let you get away with width of stair x 600 as this is usually the narrowest practical stair for a loft.
As Masona says probably best to speak to BCO as I'm not sure if the same applies for multiple rooms opening onto a landing.
Sorry just read your post again is this door at the top of the stairs on the same wall as the stairs are running up ? If so and the door is opening inwards then no minimum at all.
Just fitted one where the string of the stairs butts right against the architrave of the door.
Back to top
 Alert Moderators
a1topdog
from United Kingdom
Thanked: 2 times
PostPosted: Fri Feb 04, 2005 10:01 am Reply with quote
Building Regs Part K1
Yep - this is exactly how mine is.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
whats the minimum loft opening size? 2 900 Sun Feb 03, 2008 6:51 pm
Building regs, landing size 9 6060 Wed Feb 25, 2009 11:33 am
landing size space saver 4 80 Wed Jan 12, 2011 9:23 pm
Minimum insulation level for attic conversion 2 100 Wed Dec 19, 2012 12:39 pm
minimum distance air gap between roof and plaster board 12 240 Sun Aug 26, 2012 7:46 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
