Joined: 22 Oct 2003 Posts: 85 Location: United Kingdom Thanked: 0 times
Posted: Sun Feb 06, 2005 2:59 pm Post Subject:
Roof Space, Eaves Insulation
First of all to the moderators, i know this has been asked before by me, but i made such a mess of the post it didnt make sense. I have cleaned it up and got the diagrams sorted so i beg your indulgence.
What i want to do is.. In my eaves space i would like to insulate the inside of the triangular eaves space, effectivly the wall of the bedroom. I have rockwool set aside for this task... but i need to pick the more experienced brains that permeate this forum (thank you in advance).. First of all:
a. Is it that simple? , I'm not missing something stupid like vapour layers or something? Air flow will not be effected up through the eaves and into the attic above. and as i am not insulating the outside part of the triangle as in the roof i dont think i will be encountering any cold wall problems.
b. Can i place insulation all the way down the wall including the entrance to the void between downstairs ceiling and upstairs floor? My reasoning for this is that in a normall house this area would be sealed off anyway and its only because of the Dorma roof design that you can see this void anyway!
Thank you for any and all suggestions and comments... Over to you Breezer.
Joined: 05 Jan 2003 Posts: 11213 Location: Essex, United Kingdom Thanked: 30 times
Posted: Sun Feb 06, 2005 6:01 pm Post Subject:
That's fine as long you won't block any air flow from bottom wallplate to the top of the ridge. 50mm gap is enough. You may find it easier to use slab insulation between the upright studs
__________________ Always judge a man by the way he treats someone who is of no use to him
Posted: Sun Feb 06, 2005 10:18 pm Post Subject:
thanx for the info guys, the copper pipes are original insulation and its on the list for jobs to get done soon
there will be an airflow uo into the eaves but what about the space between downstairs ceiling and upstairs floor? can i block at each side to stop colder air getting to this area?
Posted: Mon Feb 07, 2005 9:15 pm Post Subject:
sorry masona
Im really showing my ignorance here m8, I don't understand, the gap or void between the ceiling of the downstairs and the floor of the upstairs is open on each side to the eaves. This is the problem, its cold in them there eaves and i want to stop this permeating into the floor and ceiling of the house. i would like to stop this by laying the insulation down the wall and covering this gap front and back.... In a normall house this gap would not be open to the elements and this is the point where my knowledge is outstripped by inate enthusiasm.. sorry m8.
Would you mind explaining it to me why i cant block it??
Posted: Mon Feb 07, 2005 9:18 pm Post Subject:
Told you i was thick. I read your post wrong, i think... you mean yea i can block this gap up but leave a 50mm gap before hitting the bottom of the roof????
Sorry mate , i'll go back to the day job and be quiet now..
Posted: Tue Feb 08, 2005 5:13 pm Post Subject:
In your 2nd picture do you have ventilation entering from the outside at the bottom left hand corner where the roof rafters resting on the wallplate? if so leave at least 50mm gap for air circulation.
Posted: Tue Feb 08, 2005 6:33 pm Post Subject:
Masona,
Thanx for the help mate! In answer to your question, No, but i have a good reason for this. The pic below is the outside of the area in the rest of the pics.
at the moment we have an airflow ( sometimes too much) under the lead flashing and into the eaves space. There is UPVC cladding on all exterior wood surfaces and in the near future i will be sealing the gap under the flashing and drilling 50mm dia holes for circular air vents every 6 feet or so along the upward face of the eaves to give a proper airflow into this space.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
