DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bathroom Window Frame Loose!! Cant see any way its fixed in?
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
TimB2010
from United Kingdom
PostPosted: Tue Dec 29, 2009 9:22 pm Reply with quote
Weve moved into our new house and when opening the bathroom UPVC window we noticed that the whole frame on the left hand side is loose and can be pushed out....
Ive opened the window and looked for any screws through the frame into the brickwork but cannot see any, I also cannot see any way that they have fixed in the window ?
Do some windows not have drilled fittings?
Could ours be hidden somewhere?
Many thanks in advance
Pictures:
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Wed Dec 30, 2009 12:58 pm Reply with quote
you can drill through the frame and into the brickwork and use a frame fixing or plug and screw it.then run a bead of decorators caulking on the inside and silicone on the outside.you could also use some beading on the outside if you so wish.
Back to top
The following user says thank you to Chukka63 for this useful post:
TimB2010 (30 Dec 2009)
 Alert Moderators
TimB2010
from United Kingdom
PostPosted: Wed Dec 30, 2009 1:02 pm Reply with quote
So do you think that this window has never been secured in properly?
Or have they used another method?
I dont really want to drill through the frame, as I cant see what im drilling into or whats on the the other side of the frame, but I will do if there is no other option. Cheers
Do you not think that there are maybe hidden screws somewhere that have come out/loose?
Cheers
Tim
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 1638 times
PostPosted: Wed Dec 30, 2009 2:06 pm Reply with quote
I bet its just been wedged in or secured by spray foam.....use a proper pvc window fastener, where you drill straight through the frame and directly into the brickwork without disturbing the frame any more.
Back to top
 Alert Moderators
crank39
from United Kingdom
Thanked: 253 times
PostPosted: Wed Dec 30, 2009 3:17 pm Reply with quote
As already said its more than likely held in with foam, the only thing is you'll need to remove the glass to put a proper fixing in in the bottom half of the window. Its such a small window i would push it back against the tiles, pack it tight with frame wedge packers (you can already see a yellow one in the gap) then i'd re-foam it and seal back up outside with a good bead of silicone, inside id use silicone too instead of decorators caulk as its a bathroom, those two measures should hold the window in place
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Wed Dec 30, 2009 5:11 pm Reply with quote
i doubt its been foamed in cos that stuff sticks like s**t and i always fill mine with foam, after securing, and before i seal the reveals.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Installing a fixed window in a cavity wall 3 980 Wed Dec 10, 2008 7:45 am
How do I remove fixed casement 7 660 Mon Jun 13, 2011 1:13 pm
Sliding patio door (fixed part removal) 5 1080 Thu Nov 12, 2009 3:54 pm
French doors - fixed open setting 3 680 Wed Jun 13, 2007 7:36 pm
How might my windowsill be fixed? 8 920 Thu Jul 13, 2006 2:42 pm
DIYnot
