no hot water from taps
21 Apr 2009
Ayrshire
Hi, when i woke up today there was no water coming from any of the taps, i disconnected the first fitting from the boiler and there was still no water there. It is and old potterton combi, I am a plumber myself but am not gas safe registered although i have done alot of heating work but not repairs. i may be completely wrong but could this be something to do with the divertor valve ????? help please
Jordan,
So theres no water from your kitchen cold tap ?
If not forzen supply most likely
Rico
all cold taps are fine, its not frozen, there is just no water coming from the boiler
a like your style burnerman :) al go n c if a cn top up the pressure a bit
Its at mains pressure anyway mate - you haven't heating problems, do you?
Its just to get hot water out, there's got to be cold water going in - if you catch my drift. Just wondering if that incoming cold pipe is frozen up.
John :)
av sorted it, it was a strange one, there is a tee under the sink and from it is - to the left the w/m, to the right- an elbow then up to cold tap and from bottom - straight to the boiler piped in hep2o. To the w/m and sink tap are in copper, everything was fine except about 12 inches of ice about half way up the leg going to the boiler, i still dont get why only that bit froze. I just took it out and repiped it
