DIYnot
Local | Network
   DIYnot > Forums
Local | Network
HELP:Hot water in mixer stopped due to freeze?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
shooey
from United Kingdom
PostPosted: Fri Jan 08, 2010 9:16 am Reply with quote
The hot water (only) in my mixer tap in the kitchen (near the stop tap) has stopped working. Cold water is OK, and hot water is OK in other taps.
Since the water hasn't been turned off or anything, I'm worried something has frozen?
I've got my central heating on, and that seems OK - is that safe?
What can I do about the tap? I know about the rubber grove trick - would that be any use, or would that make it worse since it'd be forcing cold water in?
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 1645 times
PostPosted: Fri Jan 08, 2010 9:25 am Reply with quote
Leave the tap open, (plug out!) open the cupboard doors and let heat waft in, and you should soon be away..... mind you, the hot pipe may have a tortuous route from the sink to the copper cylinder or boiler, depending on what system you have.
So long as all radiators are heating, there is no problem there. Just keep 'em on!
Back to top
 Alert Moderators
shooey
from United Kingdom
PostPosted: Fri Jan 08, 2010 9:33 am Reply with quote
Thanks John.
Will do as you say and report back later.
Back to top
 Alert Moderators
shooey
from United Kingdom
PostPosted: Fri Jan 08, 2010 12:47 pm Reply with quote
Once the house warmed up everything started working again.
Thanks again for you help, John!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Can water meters Freeze 3 240 Mon Dec 06, 2010 3:02 pm
Iron pipework, freeze or flood? 3 240 Wed Nov 28, 2007 7:05 pm
Pipe freeze spray kit 4 980 Wed Aug 29, 2007 6:25 pm
any one used a freeze master? 9 600 Thu Feb 28, 2008 6:13 pm
Anti Freeze in heating system? 5 1500 Mon Dec 01, 2008 3:25 pm
DIYnot
