light switch with no com input
19 Jan 2010
Warwickshire
i have just bought some replacement light switches but on the back is just 2 inputs, l1 and L2. no COM input. does any one know how these can be wired. apparently, they are mechanical switches. thank you.
With on/off switches there is no com and L1 will be line and L2 to light where the same moulding is used for 2 way and on/off L1 is marked Com and L2 is marked L1 and in real terms it does not matter if L1 and L2 are swapped.
Just hope that none of the light circuits are two-way. You'll need different switches if that is the case.
