| Author |
Message |
sheph77
Joined: 03 Feb 2010 Posts: 3 Location: London, United Kingdom
Posted: Wed Feb 03, 2010 9:51 am |
I was wondering if anyone knows where I can get a table with information on different gas meters and their capacity (in cubic meters)?
I have an existing R5 meter (which as far as I understand is imperial and rated in cubic feet) but am not sure what the actual capacity of this meter is? I am looking to install some new plant (boilers, CHP, direct fired DHW heater) and am sure that the meter will need to be upgraded. One other point is that the existing supply seems to be around two inches.
Thanks! |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
snugib
Joined: 12 Nov 2008 Posts: 675 Location: Tyne and Wear, United Kingdom Thanked: 51 times
Posted: Wed Feb 03, 2010 11:37 am |
Most domestic gas meters are rated at 6 cu mtrs/hr. or in your case imperial 212 cu ft/hr. which converts to 6 cu mtrs/hr. The capacity you should be able to see printed on the dial/read out.The R5 refers to an index which has an output pulse which can be used for on site data logging or remote modems.
Generaly domestic meters are refered to as U6(mechanical) E6(electronic) =6cu mtrs/hr.
Depending upon your requirement you may need a U16 =16 cu mtrs/hr.
The sizing of the meter requirement involves a modecum of complicated maths based on all of the appliances input or outputs and will be done by the gas transporter, who is responsible for the meter
| Back to top |
sheph77
Posted: Wed Feb 03, 2010 11:47 am |
Thanks for the reply although I am still slightly confused abotu how I can work out the size of the existing meter. The only numerical markings on the meter are R5. Does this correspond exactly to the U scale? For example an R5 = U6, R6 = U7...!?
I have found a manufacturer that supplieda number of different meters and there are q few different sizes with different letters such as:
G1.6 / G4 / G4P / U6P / E6 / SC6 / G6 / G6P / G10 / U16 / U25 / U40 / U40P / G40 / U65 / U100P / U160P
What does the G, P and E stand for in these sizes and how does it all relate to the U sizes and R sizes?
Thanks a million!! |
| Back to top |
snugib
Posted: Wed Feb 03, 2010 12:17 pm |
Look very closely at the meter index the capacity must be printed on it, usually in very small print (can you post a pic)
All those model types you quoted, all you are interested in is the digits
ie from 4 to 160 cu mtrs/hr. Not sure what all of the letters mean, maybe some manufacturers id.
I do know the U means mechanical mechanism (diaphragm) and E means electronic mechanism ( sensors that look at time of flight in the gas stream)
The R5 has nothing to do with capacity, it just means that the index provides a pulse switched output that can be used for on site data logging |
| Back to top |
snugib
| Back to top |
sheph77
| Back to top |
jmsgas
Joined: 25 Mar 2010 Posts: 1 Location: United Kingdom
Posted: Thu Mar 25, 2010 8:05 am |
hi is this a unit factory or a house with a 2inch service its normally a factory unit looking at that meter i would say its a u6
as to calculating the size of meter you would need to find out how much gas your new appliances and existing appliances will need you gas network or supplier woul beable to help |
| Back to top |
Sudds01
Joined: 23 Nov 2011 Posts: 5 Location: Manchester, United Kingdom
Posted: Sat Jun 09, 2012 7:17 pm |
Betacom 24 combi boiler glow worm,radiators not getting hot!,the boiler fire's up,the hot water side works fine!,checked the operation of the pump the impeller rotates on all three speeds,but very hot to touch,also found a small leak on the back of the 3 way valve,can any one advise me on the fault and give me remedy. |
| Back to top |
gaswizzard
Joined: 08 Oct 2011 Posts: 6278 Location: Hertfordshire, United Kingdom Thanked: 983 times
| Back to top |
BGSMJack
Joined: 02 Nov 2011 Posts: 686 Location: Cheshire, United Kingdom Thanked: 56 times
Posted: Sun Jun 10, 2012 12:23 pm |
I think he might be implying that its BGs fault... |
| Back to top |
Boilerman2
Joined: 10 Jun 2009 Posts: 4203 Location: Suffolk, United Kingdom Thanked: 721 times
| Back to top |
