- Joined
- 4 Nov 2007
- Messages
- 129
- Reaction score
- 3
- Country
Not sure how long this has been going on, because I only noticed when the pump got a bit noisy, but pump is on day and night, including when boiler is not on. I can't switch it off at the plug when I go to bed, because heating/water comes on before I get up.
I assume pump should be switched on and off by the boiler coming on and going off, so assume it could be a pcb problem.
Could a temp solution be to plug into timer so pumb comes on and goes off with water/heating, or could this cause probs. I know I could have one for example if I got a temp power cut. What could happen for eg if boiler came on and pump was off.
Cheers in advance for any halp and advice.
