i am replacing a dimmer switch that no longer clicks to the off position when you turn it
the current dimmer fitting is the only switch that operates my living room light. The room light has a combined wattage of 200w max
the current dimmer fitting has L1, L2 and C terminals
i have bought what i thought was an appropriate replacement in the "Marbo - Dimmer Single 1 Way mains voltage 250w" however this terminal only has an L and a ~ symbol (rather than the L1, L2 and C in the previous)
having returned home i have followed the instructions and fitted the red wire in the L and the black wire in the ~ symbol. The dimmer now works and switches on and off in the same manner as the other.
i just want to know whether i have bought the correct replacement and if it is safe
thanks in advance for any advice
p.s. i am a novice so please explain anything in laymans terms if possible
