Hi, I'd be really grateful of some advice on solving a problem with our central heating system. We've noticed that it keeps getting air in the system which is leading us to believe that we have a leak somewhere.
It's a gravity fed system with all exposed pipes through the whole property, so we've been round the whole place checking for leaks - nothing!
The air seems to be in one rad only which is the bathroom one and needs significant bleeding every couple of weeks.
Given that we've checked everywhere for leaks, including the loft, we can only assume that it's the primary coil in the H/W cylinder that's sprung a leak? although there is no sign of brown or debris in the hot water. We don't think the boilers at fault either as presumably you'd be able to hear the water dripping on the burner if the jacket was leaking?
Any thoughts or suggestions would be gratefully received.
Also, if there is a possibility that it could be the H/W water cylinder ( Which is only about 6 yrs old), is there some sort of dye or tracer product on the market that can be added to the header tank to see if it comes out in the hot water tap?
