- Joined
- 16 Nov 2004
- Messages
- 80
- Reaction score
- 1
- Country
Can anyone advise on the following - put up a curtain rail today, some parts of the wall were easy to drill into, but the areas directly above the window could only drill in about 2cms, I am assuming this is the lintel I'm hitting.
I was using a bog standard 700w 240v hammer drill with an ordinary masony bit (which started glowing red after a couple of minutes). I changed to a metal bit to see if that would make any difference but the same thing happened. Do I need a faster drill or a better drill bit in order to get through.
Any help would be much appreciated.
