I am having lots of problems with my Utility 15/19 unit here in rural France.It has an eletro oil B9B burner and I nave fitted the correct nozzle to suit the 35 sec Gas Oil out here. It is about 6 years old but used only for the last 3. When running it burns well and the emissions are clean.
However for the last 2 winters it has kept locking out on intermittent occassions almost every day.
Having read avidly your posts I fitted last week new danfoss coil,burner nozzle and oil non-return valve. Today it has failed to ignite at all and just loks out.
I have chaecked the spark with coil removed and this appears to be excellent.The oil is clean and the pump maintains 11-12 bar. The nozzle and surrounding baffles etc. are wet with oil indicating it is getting through o.k.
The water high temp thermostat seems to be o.k. as ,if I turn it towards minimum, the neon on the control box goes out and vica versa.I have checked for loose wiring connections.
I am seriously beginning to suspect either the Bentone TF832.3 or the flame sensor.However, these have had so little use and has anyone experienced faulty ones so new? Also, is there anything else that is the likely cause of continual locktout etc. thatI've not checked?
Your help would be really appreciated guys!
