dal5band
Joined: 03 Mar 2005 Posts: 491 Location: Surrey, United Kingdom Thanked: 6 times
Posted: Wed Feb 24, 2010 8:31 pm |
I need to replace the bulb holder on an old standard lamp - the ones in the DIY stores seem to have a different screw fitting for screwing the holder into place on the old shaft. The new ones are bigger.
What are the old and new sizes ? Can you still get the old size ?
Thanks |
RF Lighting
Joined: 31 Mar 2006 Posts: 16148 Location: Leeds, United Kingdom Thanked: 718 times
Posted: Wed Feb 24, 2010 8:35 pm |
sparkwright
Joined: 20 Aug 2009 Posts: 3059 Location: Dorset, United Kingdom Thanked: 356 times
Posted: Wed Feb 24, 2010 9:28 pm |
From memory, plastic lampholders have a larger threaded end than the brass ones.
If you use a brass one make sure it is earthed (you may have to replace the flex). |
333rocky333
Joined: 12 Jan 2008 Posts: 3618 Location: Essex, United Kingdom Thanked: 200 times
Posted: Thu Feb 25, 2010 2:27 am |
10mm, 13mm and 1/2 inch are the most common sizes |
dal5band
Posted: Thu Feb 25, 2010 3:32 pm |
Cheers - 13mm is almost 1/2 inch so I persume the 10mm is the smaller size. Now I know what to ask for !! |
RF Lighting
conny
Joined: 30 Jun 2008 Posts: 8763 Location: Liverpool, United Kingdom Thanked: 67 times
Posted: Thu Feb 25, 2010 7:53 pm |
At those prices I'd need a mortgage!
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41399 Location: London, United Kingdom Thanked: 1337 times
