DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
EXTERIOR LIGHT SWITCH
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
Mike_Southampton
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 23, 2005 9:47 am    Post Subject:
Reply with quote Thanks
Good morning helpers,
I am trying (IN VAIN) to wire an outside
waterproof light switch. On the back at the top
are conections 1 & L at the bottom is 2 can someone please help. I have 1.5 t&e cable.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Feb 23, 2005 11:24 am    Post Subject:
My guess would be that it's a 2-way switch, terminals for which are usually labelled COM or C, L1 and L2, or sometimes L1, L2 & L3.
Which combinations have you tried? L and 1 would be my first attempt (actually, my first action would be to identify which was which with a multimeter, but I've learned that lots of people don't think they need one of those in their toolbox)
Is your problem just that you don't know which terminal is which, or that you don't understand at a more basic level how lighting circuits are wired? Have you looked at the diagrams in the For Reference topic, or invested in a copy of the Which? Book of Wiring and Lighting?
As an aside - how are you getting the T/E cable into the switch and retaining its IP rating?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Mike_Southampton
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 23, 2005 11:53 am    Post Subject:
Hi,it feels ive tried most combinations so far.
It is a IP55 push on/off switch (grey plastic box rubber gland)
with 1 & L on top with 2 at bottom. Seperate earth in box.
In & out T&E into box using correct T&E cable gland connector
I have tried both reds, both blacks in various connections but keeps tripping
my house rcd.
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 23, 2005 1:25 pm    Post Subject:
Aha - sounds like you are trying to wire a single pole changeover switch as if it were double pole. The neutral and earth wires should not go through the switch, but straight through from supply to load - as you have already cut into them however, I suggest joining black to black with a piece of choc-bloc, tied back with a cable tie if there is risk of it flapping about and fouling anything else.
Earths can be joined at the terminal already in the box.
Only the red (live) should pass through the switch, and as the other posters have said, use L as input and 1 as output, at least as a first go. If the switch operates 'upside-down' swap 1 with 2. If nothing happens at all, swap L and 2.
Let us know how that goes
regards.
M.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Feb 23, 2005 3:48 pm    Post Subject:
RCD or MCB?
You say "both reds, both blacks", which means 2 cables, not one. Where do they come from/go to?
If you aren't trying to use this switch in the usual way (i.e. with a single switch cable), have you got an incoming cable with L&N, and you want an outgoing with switched live & neutral?
If so you need to join the neutrals with a bit of choc-block and just put the lives into the switch.
__________________
Back to top
 Alert Moderators
Mike_Southampton
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 23, 2005 7:13 pm    Post Subject:
icon_biggrin.gif Thanks to both of you guys mapj1 & ban-all-sheds
You are both life savers all working fine and the missus is happy and good chance of now being able to watch tonights footie.
Thanks again Mike.
Back to top
 Alert Moderators
NATHAN_JONES
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 08, 2005 9:02 pm    Post Subject:
Mike -
Can I ask where you got your switch? I'm struggling to find one for external mounting.
___________________________
moderator
please note 17
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
Second exterior light and moving light switch 5 560 Mon Aug 09, 2004 12:36 am
exterior 1 gang light switch 10 6280 Tue May 11, 2004 12:35 pm
Exterior PIR sensor light 3 280 Sun Nov 11, 2007 2:25 pm
What do I do with the earth cable on an exterior light? 7 280 Thu Jan 01, 2009 2:11 pm
Adding an exterior light 5 520 Thu Jul 27, 2006 5:29 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
