Painting woodwork outdoors
7 Mar 2010
Lancashire
Hi All
Love this forum by the way!
Can you please tell me when is a good time, if there ever is a good time, to repaint my very old (some a little rotten!) window frames? All the old stuff is flaking off and bare wood is showing.
What is the best way to go about attacking them bearing in mind that I am on a very small budget :cry:
All advice truly appreciated.
Wait til the prospect of dry weather, at least a week prior to starting if possible! (I dont start my exteriors until May ) rub-down old paint or burn back to bare wood if needed on flaky / cracked paint,prime bare wood then undercoat & gloss with Dulux Weathershield or All Seasons.
thanks for that info. Roll on the good weather then!
Can i just fill any gaps in the frames with a good exterior wood filler?
What about loose putty? :)
I use Isopon P38 car body repair filler, its basically the same chemical makeup but cheaper than wood filler and easier to sand..Been using it in place of woodfiller for 25+ years ;) .. If you have any soft wood treat it to a couple of applications of wood hardener first.
I quite often use Crown Stronghold undercoat first as it covers slightly better than the Dulux , followed by Weathershield gloss..
Best buy your paint from a trade store , the stuff from DIY outlets , even brand names, is thinner/inferior ;)
I talked to the guy at Leyland about that a few weeks ago - and he reckons that they are identical. That it's just an urban myth.
Maybe with Leyland but Dulux & Crown trade are definitely a different formula, I know, I worked in a trade store..Email Dulux and theyll confirm..DIY sourced paints are diluted/thinned to ease use by novices..
