DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Shower install, 10.5kw on 6mm cable?
Author Message
darchy
from United Kingdom
PostPosted: Tue Mar 01, 2005 10:41 am Reply with quote
Hi, I am about to fit a new shower into my bathroom, i have bought a 10.5 kw triton shower. There is already a shower pull cord switch in the bathroom with a 6mm cable leading to the fuse box which has a 40A RCD & 100A main switch. is this setup ok?
your opinions would be appreciated
Many thanks
Shaun
Back to top
 Alert Moderators
kai
from United Kingdom
Thanked: 42 times
PostPosted: Tue Mar 01, 2005 11:22 am Reply with quote
No - you must use a 10.0. sq.mm. cable at the very least - have you filled in the Part P Building Notice to the Local Council yet?
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 2 times
PostPosted: Tue Mar 01, 2005 1:08 pm Reply with quote
That pull cord switch might be rated at 30 amps only, in which case the contacts should burn quite nicely. A 40 amp breaker is only good for 9.6 kilowatts.
Back to top
 Alert Moderators
darchy
from United Kingdom
PostPosted: Tue Mar 01, 2005 1:45 pm Reply with quote
Great thanks for that, thats cleared up a few doubts I had in mind, I'll now return the shower & exchange for a lower rated unit. What would you guys advise is the maximum you would fit in such a specification? I'm not looking to rewire the run to suit the shower, however, if needed i would consider upgrading the RCD etc.
Cheers again
Shaun
Back to top
 Alert Moderators
darchy
from United Kingdom
PostPosted: Tue Mar 01, 2005 1:52 pm Reply with quote
I've just checked the pull switch again & it is rated 45a. Just another quicky, i'm probably wrong but I thought that it was ok to wire in/change a shower to an existing installation without notifying the council?
Shaun
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 2 times
PostPosted: Tue Mar 01, 2005 2:37 pm Reply with quote
Your 40 amp breaker is good for a 9.5 kW shower. The cable is actually rated at 51 amps in free air but only 37 amps in conduit. Where is yours? An 8.5 kW shower will leave you some spare breaker capacity and draw a fraction over 35 amps. Long, long ago I had a 7 kW shower. The flow was a bit slow in winter but it still worked and was cheaper to run. You don't have to have the biggest shower in the shop.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 146 times
PostPosted: Tue Mar 01, 2005 3:02 pm Reply with quote
I don't think I'd want anything over 8.5kw on 6mm (this does *not* imply that 8.5kw and below is definaly ok on 6mm, all depends on volt drop, disconnect time, specing factors, etc), and even then, 10mm would be better even then.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 457 times
PostPosted: Tue Mar 01, 2005 4:38 pm Reply with quote
Are we using 230V in our calcs?
40A at 230V = 9,200W.
The general feeling here is that 6mm2 is good for up to 8.5kW.
As Adam says, though, this is NOT a hard and fast rule.
Back to top
 Alert Moderators
darchy
from United Kingdom
PostPosted: Tue Mar 01, 2005 4:59 pm Reply with quote
The shower itself is rated 10.5 KW @ 240v. Deeper in the book it gives a rating of 9.6kw @ 230V, using that guide, the 8.5kw should be approx 7.8kw @ 230v, the 9.5 is 8.7 @ 230v. I feel the 8.5 @ 240 would be much better for my purposes as I can't justify having the cable replaced (cost reasons). The fuse box in my house is located in my front porch, the shower cable + all others then go up the inside wall into the attic (this is in a large uninsulated plasterboard box section) , across and into the bathroom pull switch
Cheers again to all of you for your help
Shaun
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
cable size and mcb for shower install 2 2420 Thu Mar 27, 2008 8:57 pm
shower Install 4 160 Fri Oct 24, 2014 7:48 pm
Install a new MCB on board for a shower? 2 1520 Wed Aug 08, 2007 3:27 pm
Shower extraction install - ceiling or wall? -approx cost? 6 320 Wed May 12, 2010 12:30 pm
New Electric Shower Install 5 1200 Fri Mar 09, 2007 12:10 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
