Joined: 01 Mar 2005 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Tue Mar 01, 2005 10:13 pm Post Subject:
noisy soil pipe
Is there anyone who can help with this-(PLEASE).I live in a house which is now 6 years old,since day one we have had to suffer an extremely loud and annoying banging/tapping/thudding noise from the soil stack.This happens when you drain hot water away after washing,having a bath etc,if we then run the cold water the tapping noise stops for a few seconds then starts again if you leave the cold water tap running the tapping eventually stops after a few minutes.As you can imagine this is extremely annoying especially when having a shower or after a bath.The builder at the time only told us that it was the soil stack contracting and put some glass wool between the stack and some wood which they thought the stack was contracting against,this stopped the problem for 1 hour!!! Has anyone heard of this before and how can this be cured?
Joined: 03 Jan 2005 Posts: 317 Location: United Kingdom Thanked: 0 times
Posted: Tue Mar 01, 2005 10:52 pm Post Subject:
unfortunatly the explanation that you were offered by your builder is likely most likely to be correct - you need to try to find what the stack is rubbing against as it expands/contracts - hopefully (but unlikly) you may have some access to the stack - if so try to pack between the stack and any contact (including brackets)
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Wed Mar 02, 2005 3:10 pm Post Subject:
COuld well be it never had enough expansion joints, or the pipe was fixed to the wall wrongly or so it has nowhere to move. It's astonishing how much New Build you see done incompetently. Find a better plumber!
Posted: Wed Mar 02, 2005 5:00 pm Post Subject:
There is access to part of the stack by taking the bath panel off and reaching a small part of it,this is where we have tried packing glass wool between the stack and anything it touches but to no avail.
As i can only reach a small part of the stack is there anything else i could try,is there anything a plumber could do?
Posted: Wed Mar 02, 2005 5:08 pm Post Subject:
Oh, an INTERNAL plastic stack They're always horribly noisy. Often there's a loud noise due to water simply dripping and hitting something like an angled bit of pipe.
IF the noise is due to thermal movement, you might be able to break into the duct somewhere (plasterboard, probably ) and cut a section of pipe out, replacing it with the section slightly shortened, and a couple of SLIP couplings which have rubber seals at the ends so the pipe can move - silently.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
