DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
leaking bath
This topic originated from the How to page called Tiling around a bath
Click here to return to the page called Tiling around a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
tamark
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 02, 2005 9:02 pm    Post Subject:
leaking bath
Reply with quote Thanks
when i had my bath fitted after a few months i noticed the ceiling below getting damp, i re sealed the bath surround with unibond sealer and after a few weeks the sealent has come away from the bath, a friend told me that i would have to take the bath out remove the bottom row of tiles and start again. big problem there... the bath has been set into the wall and housing has been made at the side of the bath for some pipes...help!! icon_cry.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
markf
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 03, 2005 4:44 pm    Post Subject:
Are you sure the water is getting between the bath and the tiles. the leak could be from a poorly connected overflow pipe, the waste pipe note connected to the U-bend properly, the U-bend not being connected to the plug waste, or even a weeping tap connector.
Check these connections are tight and fill the bath. Check underneath the bath for any signs of water ingression or leaks - then pull the plug and check the waste pipes and unions for leaks. If any of the latter leak then try tightening them up again and ensure they are not strained (i.e. pulling tight on the pipe when changing direction). If the leak is at the unions and tightening them doesn't cure then you could try a bead of plumbers putty around the join.
If the leak is coming from around the bath edges then strip off the silicone seal and re-apply. It is vital that the bath is FULL when applying silicone, and that is left full for 24 hours until the silicone has cured sufficiently.
I personally cannot see what benefit you will gain from removing the bottom row of tiles and refixing - unless the tiles do not touch the bath top when the bath is empty. They do go right down to the bath icon_question.gif
Good luck.
Back to top
 Alert Moderators
tamark
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 04, 2005 7:29 am    Post Subject:
hi markf,
thanks for your info on the leaking bath, but i think the water is coming from the sides as this happens when we shower.is there any way to fix it without taking the bath out and removing the tiles icon_cry.gif
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Mar 04, 2005 11:21 am    Post Subject:
Take the side panel off and check the adjustable leg is tight up to the row of tiles then fill the bath with cold water and reseal it, empty bath water when dried.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
brownieddie
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 07, 2005 3:15 am    Post Subject:
When you have the panel off try putting some sealant in from underneath as well as above, worked for me.. icon_wink.gif
Back to top
 Alert Moderators
david and julie
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 07, 2005 1:55 pm    Post Subject:
Just out of curiosity is it the acrylic sealer rather than proper silicon you have used? Although they are advertised as bathroom sealant I have never found them as good as a top quality silicon made is for this purpose.
When your friend mentioned removing the bottom row of tiles they probably meant to insert a proper plastic sealing strip below/behind the tiles and then re-tile over it. This would of been preferable at first but is probably not worth the effort now.
Properly applied silicon should do the job.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Leaking corner of bath 3 420 Mon Sep 29, 2008 8:50 pm
Leaking shower tray/ cubicle 19 8720 Sun Mar 06, 2005 2:26 pm
Leaking shower tiles 3 3140 Mon Oct 24, 2005 10:21 am
Knots in wood leaking 2 300 Fri Jan 16, 2009 8:36 am
Leaking tiled shower enclosure 21 17940 Sat Apr 01, 2006 4:51 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
