DIYnot
Local | Network
   DIYnot > Forums
Local | Network
High pressure, combi boiler, how to release?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
crissybwoy
from United Kingdom
PostPosted: Fri Mar 04, 2005 8:47 am Reply with quote
Hi, first post here, I've been to these forums before but never needed to post as i've found the info I needed before but cant find what I need this time.
I recently moved into a house, it has a Vokera Maxin combi boiler. Had a problem with one of the rads (it fell off the wall) but have sorted that out, now the boiler has pressure going past 3 bar (after sorting the rad I set set the pressure a 1 bar). Is there any way of me sorting this myself or should I be calling out a plumber.
Is my boiler going to explode?
Cheers
Crissy
:EDIT: I noticed the high pressure when the hot tap in upstairs bathroom stopped working.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 79 times
PostPosted: Fri Mar 04, 2005 9:17 am Reply with quote
Has the filling loop been removed?
Reduce pressure by draining some water out of a drain point under a rad.
If pressure keeps rising, suspect the pressure vessel needs recharging. icon_sad.gif
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Fri Mar 04, 2005 7:06 pm Reply with quote
BAHCO wrote:
...........Reduce pressure by draining some water out of a drain point under a rad.
It's easier to use the pressure relief valve, and if it leaks afterwards, either the water is dirty or the valve is duff. Replace it. If the expansion vessel needs attention, the valve is probably operating now and again anyway.
Back to top
The following user says thank you to oilman for this useful post:
bawdry (31 Mar 2011)
 Alert Moderators
crissybwoy
from United Kingdom
PostPosted: Fri Mar 04, 2005 7:47 pm Reply with quote
Cheers for the replies! Where would I find a pressure release valve icon_eek.gif ?
Cheers!
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Fri Mar 04, 2005 8:15 pm Reply with quote
it's the bit of brass with the red plastic cap
Back to top
The following user says thank you to kevplumb for this useful post:
 Alert Moderators
crissybwoy
from United Kingdom
PostPosted: Sat Mar 05, 2005 8:15 am Reply with quote
Cheers for that, found the brass bit with the red cap inside the flap on the boiler front that you have to unscrew. Good job I've seen some heating engineers work on similar boilers or I would of had to ask where the pressure release valve was!
Cheers for all your help. Boiler now sorted!
Crissy
Back to top
 Alert Moderators
PEDANTICVINDICTIVEMAN
from United Kingdom
Thanked: 628 times
PostPosted: Sat Mar 05, 2005 8:26 am Reply with quote
Thatl'l be £5000.00 callout plus parts, send money to any local criminal, the numbers are in the yellow pages uner CORGI gas fitters.
Back to top
The following user says thank you to PEDANTICVINDICTIVEMAN for this useful post:
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Combi-Boiler at 3-bar!! How can I release some pressure??? 17 4200 Wed Sep 03, 2003 8:45 am
how to release water pressure from alpha 240e combi boiler 3 60 Mon Feb 21, 2011 6:00 pm
BAXI Combi Instant 80 HE needs to release pressure 10 1480 Tue Jun 10, 2008 12:16 am
Pipe from pressure release valve on a combi 18 3300 Thu Nov 09, 2006 5:56 pm
How to release pressure on Worchester Greenstar1 Jun. Boiler 2 340 Sat Jan 09, 2010 7:33 am
DIYnot
