I am installing few Air-Conditioning (A/C) units in my home - cable length from A/C units to Consumer Unit (CU) range from 7m to 30m. The A/C units capacity range from 1.2KW to 1.9KW. I have used 2.5mm (singles: red, black, 1.5mm Earth) cables to run each A/C unit's 20A scoket direct, as separate circuits to the CU. My CU is Wylex - triple Phase Board - 12 ways (36 singles), I'm using single phase MCBs - Type C.
Questions:
1. Is it ok to use the 2.5mm cable to run the connections to the CU?
2. How do I protect the circuits - what rating of MCB should I use to protect each circuit? Note that the A/C units are: 1.2KW x 7 units, 1.2KW x 2 units, and 1.9KW x 5 units. 14 individual circuits.
3. Is Type - C the right MCB to use?
4. The CU has no RCD protection. I really want to have the house protected against electric shock. How can I do this? I am thinking of changing the 125A Incomer disconnector Switch (4Pole) to RCD Incomer. Is it possible to do this? I understand that the CU will trip off rather than the affected circuit only - switching off the entire power of the house. What is the alternative? If this is possible what rating of RCB do I need to use?
5. Because my CU board comes with Type C MCBs, its means that all the circuits may have to be protected using this. Is this ok? What rating should I use for the lights, Sockets, and as well as the A/C units as explained above?
I really will appreciate your advice and recommendations as always.
Questions:
