Got up this morning, freezing cold. Boiler not working. The system pressure guage is just above zero. red limit indicator is on. pump is working but sounds like air is in the system. any help would be much appreciated
Yep did the job. Works fine, i had to top up the water pressure a few times while bleeding the radiators. Brilliant! thanks for your help. Top website!!!!
Glad that you are sorted but keep an eye on the pressure guage.
You may need to top up occasionally.
If regularly, you have a leak somewhere and will need to find it.
Also. the filling loop should be disconnected after use.
