DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cable in cavity
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
  View previous topic :: View next topic
Author Message
flyman
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 08, 2005 1:27 pm    Post Subject:
cable in cavity
Reply with quote Thanks
how to feed alarm wire up a wall caverty
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 08, 2005 4:36 pm    Post Subject:
take wall down completly and re-build around the cable
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 08, 2005 4:39 pm    Post Subject:
You don't feed it up, you drop it down.
1) Try to find out whether or not you have a clear route. There might be insulation in there or even a cavity tray.
2) Drill a hole through the outer leaf where you want your wire to come out.
3) Tie a small weight to the end of a piece of string. Actually, fishing line is best if you can find it. The weight should be heavy enough to pull the line through the hole and be roughly bullet shaped. An old bullet will do nicely!
4) Drill a hole through the inner leaf DIRECTLY BELOW the first one.
5) Push the weight through the outer leaf into the cavity and let gravity take it down. If it catches on an obstruction, jiggle the string about and hope!
6) When the string comes down past the lower hole, fish it out with some kind of hook.
7) Pull plenty of string out through the hole, tie your alarm wire to it and pull the pair of them back up. You may or may not be able to pull your weight back out.
It's a tricky business at the best of times. It can be done but you'll need accurate measurements and quite a lot of luck.
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 08, 2005 4:42 pm    Post Subject:
trick: use trunking lid instead of string.
Back to top
 Alert Moderators
theshogun
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 08, 2005 5:24 pm    Post Subject:
To hook the string drill 25mm bottom hole insert folded tape measure and feed into the cavity , i find 5m metal tape works best. Then drop your string with weight attached from top hole, when it goes past the bottom hole retract the tape and hopefully the string, Good luck icon_biggrin.gif icon_biggrin.gif
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Tue Mar 08, 2005 6:27 pm    Post Subject:
Or if your tape measure is too shiny, use the plastic strips used to secure parcels together.
Fishing weights are great.
s***s law says there wil be a cavity tray, a double lintel, cavity wall insulation etc.
Trunking lid aint gonna work.
And you do know you aint meant to run cables in cavities icon_wink.gif (In the eye of building regs, the cable could allow damp to track across the wall. In the eyes of NIC, the cables could be damaged during installation).
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Mar 08, 2005 6:42 pm    Post Subject:
as mentioned trunking no use on long runs (great over false ceilings) fishing line / thin wire and bent over coat hanger are very good, doestake practice and holes MUST be in vertical alinment. I used to do it a lot, if you dont get it within 3 "pulls" you aint going to because its not there
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 08, 2005 6:45 pm    Post Subject:
your in a room with 4 false walls. were u susposed to put the cables?
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Tue Mar 08, 2005 7:10 pm    Post Subject:
If we are talking block external walls - chase them. You aint meant to wire in cavities.
Internal stud walls, of course you can.
Internal block cavities that are there due to extensions.......umm......
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Running Cable in Cavity Walls... 4 940 Tue Aug 29, 2006 3:27 pm
cable in cavity space 4 480 Mon Jan 22, 2007 11:07 am
Cable in Cavity Wall? 4 440 Sun Aug 24, 2008 8:01 am
Cable in wall cavity 31 2080 Thu May 12, 2005 11:45 am
Greetings, 2.5mm cable up the cavity 15 620 Mon Aug 03, 2009 1:29 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
