DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ceiling Joist Repair, rotten wood
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
Author Message
Rowan11
from United States of America
PostPosted: Wed May 19, 2010 6:13 pm Reply with quote
I am renovating a rental property. In the bathroom we have found severe wood rot in 1 of the 3 main ceiling joists. The rot goes through 2/3 of the joist (4 2x10 with 1x6 on each side) on the right side of the joist, approximately where the rot ends is the bathrooms vent pipe which is what makes this hard for me. Should I cut the rot straight out, replace the wood and sister on each side? Is that enough support?
We have discussed interlocking the new wood with the old, bolting the wood, and adding a 4x4 post on each side of the vent pipe.
Any input would be appreciated.
Back to top
 Alert Moderators
ladylola
from United Kingdom
Thanked: 249 times
PostPosted: Wed May 19, 2010 7:33 pm Reply with quote
I'd always be inclined to take out any rotten timber and generally some of the adjoining timbers as there may be unseen infection. For example we normally cut out something like a metre (just over 3 feet) past any rot.
Wheather to replace the entire joist or to repair with a bolted on section can be as simple as looking at what work is involved, it will probably be easier to replace unless this would involve tearing down undamaged sections of the building.
Don't forget to identify what is causeing the rot (probably moisture) and take measures to prevent it.
If you can could you post some pictures of your problem as this will help us to advise you much easier.
Back to top
 Alert Moderators
Rowan11
PostPosted: Wed May 19, 2010 7:57 pm Reply with quote
There is about a metre of rot and mold. The rot is quite extensive as I can pull large chunks of the joist with my hand. There is a wall sitting almost directly beneath the joist, however it is not load bearing. Only 1/3 of the joist sits on the underlying wall which has lead me to the doubts. What is the best way to insure proper weight distribution when repairing the joist? I am thinking of a lap joint with glue, deck screws, and toggle bolts. Would this be sufficient or do I need to add support via a beam on each end of the repaired joist? As for the moisture we have pinpointed it to a leak in vent boot on the roof.
I will post pictures this evening as I am looking to solve this issue in the morning.
Back to top
 Alert Moderators
chippy5
from United Kingdom
Thanked: 13 times
PostPosted: Wed May 19, 2010 8:18 pm Reply with quote
bite the bullet replace the whole joist then you know its stable. could be quicker than trying to cut a joint in situ. is the renovation covered by building regs? if so they would probably want a new joist
Back to top
 Alert Moderators
RonnyRaygun
from United Kingdom
Thanked: 192 times
PostPosted: Thu May 20, 2010 8:42 pm Reply with quote
Is it wet rot or dry rot? Dry rot is much more of a problem and you need to be very careful to fully eradicate it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Rotten Joist 10 8220 Mon Nov 27, 2006 8:56 pm
Rotten joist in bathroom under showerbath. 4 320 Fri Jan 07, 2011 6:47 pm
Rotten wood repair help please 3 220 Mon Oct 06, 2014 4:59 pm
how to repair a pair of rotten joists? 9 1120 Thu Apr 15, 2010 5:19 am
hardener for rotten wood 2 140 Mon Jul 11, 2011 1:19 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
