Hi
Every time the hot water pump turns off, I get one very loud bang!
It used to do it on speed 3 setting, I reduced it speed 2 and it stopped...two months later and it\\\'s doing it on speed 2 now ....help please.
Thanks M8
"zone valve or three port valve sticking" ...
All I can see is two motorised valves near the pump,with one pipe in and one out each...so I'm not sure if there is a three way valve or a zone valve!
