Wiring downlights question
17 Jun 2010
London
Hi all, newbie on here so go easy on me :cool:
Need some advice from someone who knows regarding fitting some downlights.
My house has 1.0mm wiring lighting cable into the loft which currently connects to the single ceiling rose for a pendant type light.
I would like to do away with that and fit 6 x downlights and I am thinking GU10 bulb downlights.
Without upgrading to 1.50mm wiring, so sticking with the original 1.00mm wiring, what type/wattage GU10 bulbs(6) can I run safely?
Many thanks for shedding any light on this :D
How many lights are on the existing circuit and what rating is the protective device ?
Three bedroom lights, bathroom light and upstairs hall lights.
Bedroom 1, 1 x 60w bulb (being replaced as described above).
Bedroom 2, 6 x 20w low voltage spots with two transformers.
Bedroom 3, 1 x 60w bulb.
Bathroom, 2 x 40w bulbs.
Hall, 2 x 60w spots.
All the above on a single old type 5A fuse, been like that for years working fine.
That'll be 440 watts then. ;)
230v x 5a =1150 watts.
1150-440=710 watts.
You have 710 watts spare capacity on your circuit.
Downlights are hideously inefficient. I just had my new house rewired, and asked that the electricians remove all the halogen monstrocities and fit pendants. :evil:
The only place I have downlights is in the kitchen. I have two, total load 52 watts. Total light in the kitchen 72 watts. And its VERY bright.
______________________________________________________________
If I were you I'd re-prioritise my spending on replacing that fuse box. A fuse wont save your life if you touch a live wire, a new RCD protected consumer unit will. Also, your wiring may need updating.
Steve I must as the obvious...
how come you didnt rewire yourself?
Reading your posts it seems you are already experienced :confused:
To be honest, I didnt want to make the mess myself.* I dont have a wall chasing diamond saw (with a henry attached) and SDS drill. Doncaster MBC's LABC dept makes it hard work notifying too. I didnt fancy chasing with a chisel and hammer. Electrician can get things on the cheap. I'm not paying full whack because he did it as a "weekend job".
*Think about it, you just paid for the biggest single investment in your life, got into loads of debt for it, would YOU want to go knocking it about making a big mess of it as soon as you're in? :LOL:
Ah yes I think I remember a post about Doncaster LABC.
Shame because skilled people like yourself are being put off, whilst unskilled joe bloggs is going round and doesnt give a monkeys :evil:
That is something that I will get done sooner rather than later - anyone care to throw in a ball park figure to have that done by a proper electrician?
Thanks for your input, looks like I am safe to go with the above then :cool:
