My central heating cold feed tank overflows continually; not ball valve; rad nearest pump always needing bleeding; lots of air in the system; when pump on it often streams out; set volume in cold feed to low, cleaned system out with Sentenal but still streams out; This all happened after heating was switched off last summer, emptied system, removed rad to decorate; then re-filled. Any thoughts?
