beko wma 745s not working
24 Jun 2010
hey everybody,
I have a beko washing machine that has stopped working,there is a display that is constantly flashing the letters Li,and the 1200 light is also flashing,have cleaned out the filter and all the usual stuff,there is nothing in the manual about this! any advice would be much appreciated,thanks
hi have you had any luck with finding the answer to this fault. i have the same problem.
Li is not a valid error code (maybe it is Italian for broken pcb?).
Try a restart by pressing (and holding) the start button for min 3 secs. If that doesn't help try this:
Make sure the program selector is NOT in the spin position. Turn off the power. Press & hold the start button, then turn the power on. The start led should begin to flash in approx 3 secs. Release the start button & turn the program selector to spin. Then press the start button again. This ought to reveal the actual error code (post that here). Press the start button for min 7 seconds to clear all error codes from the memory.
If the error is cleared successfully all the led's go out. This doesn't mean the problem goes away...it just means the memory has been cleared. Let me know what develops.
