Shower pump plumbing
25 Jun 2010
HI, I'm installing a shower pump and have a question.
I want the unit to sit on the floor, but that would mean I need an extra 3 foot of piping to reach down and the same to get back up to the pipe.
Can I use white flexi pipe or would it have to be copper?
Cheers
Flexi pipe (if you mean plastic barrier pipe) is fine. I'd recommend Hep20 grey pipe with John Guest Speedfit fittings if you are going to use plastic.
Make sure its all clipped tightly too.
Should run 22mm pipe from CWSC and DHWC to the pump and then can take it in 15mm to the shower valve
Sorry, I'm a novice, can you explain CWSC and DHWC please?
Also, the pipe runs up through the attic to the shower, is it a bad idea to have the pump in the attic? I get the general impression that it would be, air traps etc, so I wanted to put it in the airing cupboard, but it would be much simply to stick it in the attic!
And one last thing, I did ask this in the electrical but as yet no reply, could I wire a plug to the pump or does it have to be wired to a wall fuse box (spur?)
Cheers
You don't!
Buy a couple of high density concrete blocks and put them on the floor, with the pump atop that. The pump can jiggle about but if it does it on the floor it'll be LOUD. The mass of the blocks means they won't move much. The pump should have rubber feet. You need surprisingly small soft feet to isolate the vibrations.
Some people use carpet or underlay but it squashes quite quickly.
A layer under the concrete might help a bit.
Cold water storage cistern (tank in the loft)
Hot water storage cylinder
Use a "flange " such as an Essex, Warix or Surrey.
It should be on its own spur but many aren't. And RCD protected.
Yes. Explanation is long - best with a better head of water behind it.
You don't!
Thanks for the tip
Ok, thanks, probably should have said it's a single impeller, so I'm going for hot only
