DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Rad valves
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
chrisloz
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 22, 2005 1:18 pm    Post Subject:
Rad valves
Reply with quote Thanks
I am in the process of replacing a radiator. The bits from the old one are all chewed up and unsightly so I bought new push-fit tails from B&Q. The nuts at the lockshield end fit fine, but not the control valve end. It fits to the radiator OK, but is just a gnats too big for the valve end. Any suggestions??
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ArtfulBodger
Thanked: 0 times
PostPosted: Tue Mar 22, 2005 4:38 pm    Post Subject:
Are you saying you are trying to fit the new valve to the old rad connector? if so, why not just take the old one out?
Back to top
 Alert Moderators
chrisloz
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 22, 2005 4:52 pm    Post Subject:
Not quite sure what you mean. Basically, I've got the new rad hanging on the wall; to the left is the lockshield end which is fitted up fine. The connector I bought has an adjustable push fit on the radiator end with a tightening nut. The other end is similar but the end of the pipe is flared out slightly so it won't fit inside the valve and I can't get the big nut onto the thread to tighten it. Make any more sense?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Tue Mar 22, 2005 5:13 pm    Post Subject:
What push fit are you using?
The rad with valve on normally sits on top of the feed pipe and you tighten a compression nut with olive onto it.
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Tue Mar 22, 2005 5:18 pm    Post Subject:
You'll have to file it. We often find that cheap plumbing stuff doesn't fit properly.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Tue Mar 22, 2005 5:29 pm    Post Subject:
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
which rad valves for microbore 4 360 Fri Mar 28, 2008 3:36 pm
rad valves 5 140 Tue Apr 01, 2008 7:08 am
Help, choosing towel rail / radiator inc valves 11 800 Wed Mar 26, 2008 7:48 pm
Thermostatic Radiator Valves 5 700 Sun Mar 23, 2008 10:10 am
Boss White and Plumbers Mait: Rad valves 3 420 Thu Mar 20, 2008 10:02 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
