DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Megaflow overflow pipe dripping
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
dillonrob101
from United Kingdom
PostPosted: Tue Jul 06, 2010 8:54 am Reply with quote
Hi
We have a megaflow system and the outside overflow pipe is continuously dripping with hot water, we have tried the flowing but it only slow it down for a short time until the main water is turned back on
Isolate cylinder
turn on the lowest hot water tap until water runs out
hold open the temperature and pressure release valve (on the side of the cylinder) until the gurgling stops in about 15 to 20 minutes. Then close the valve turn water to cylinder back on
wait until water is flowing from tap
shut off tap
any advice welcome[/b]
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 273 times
PostPosted: Tue Jul 06, 2010 9:01 am Reply with quote
All megaflos fail in this way.
You were taken in by the marketing of a flawed design being promoted as a benefit - the so called floating baffle. Its only purpose is to prevent water and air mixing and it doesn't work. Heatrae-Sadia know that, that's why the instructions are printed on the side of the cylinder.
If you can't stop the leak from the PRV you will need it to be replaced by an unvented G3 cardholder. Buy two, you'll need another in the next 5 yrs.
Back to top
 Alert Moderators
dillonrob101
from United Kingdom
PostPosted: Tue Jul 06, 2010 11:39 am Reply with quote
thanks for the info
Back to top
 Alert Moderators
vulcancontinental
from United Kingdom
Thanked: 1711 times
PostPosted: Tue Jul 06, 2010 2:26 pm Reply with quote
They also used to send out, free of charge, a potable water expansion vessel when the problem arose in the first place. They soon stopped that when the extent of the problem became apparent.
Buy your P/TRV and also buy and fit an expansion vessel suitable for potable water. You'll still need to replace your T/PRV again later but maybe you'll get a little more life out of it if you live on a soft water area.
Great idea eh? Test the safety devices each year knowing that in a lot of cases they are difficult to get to reseat properly afterwards and may need replacement.
Back to top
 Alert Moderators
shawd
from United Kingdom
Thanked: 26 times
PostPosted: Tue Jul 06, 2010 9:09 pm Reply with quote
could be a couple of things, air bubble requires recharging, make sure if you have mixer taps fitted that the hot and cold are not mixing inside the tap, if you have rechrged the mega flo that the t and pr valve is not faulty by not shutting off correctly, I personally think that the mega flo is a great bit of kit and is better than the santon prem plus with the external vessel which may also need charging periodically.
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Tue Jul 06, 2010 10:16 pm Reply with quote
This will invalidate the agrement approval unless you get written confirmation form Heatrae that it's ok to do it.
Back to top
 Alert Moderators
vulcancontinental
from United Kingdom
Thanked: 1711 times
PostPosted: Wed Jul 07, 2010 5:57 am Reply with quote
That's really interesting as they sent one out very early on FOC.
Not saying your wrong but they did when the problem first arose.
The line was, oh, it's the water type in your area.
This was a long time ago, early nineties I'd guess, it's all so hazy to me now.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Megaflow Cylinder Overflow Dripping 2 2200 Thu Jul 28, 2011 10:06 am
Dripping Shower Megaflow Recharge for Noob 11 400 Thu Dec 02, 2010 3:29 pm
Megaflow early version pressure relief dripping 7 2520 Tue Mar 27, 2007 9:22 pm
Megaflow DD145 - is this dripping worrying? 3 120 Sat Aug 17, 2013 3:42 pm
Water dripping through tundish - Megaflow Unvented Cylinder 14 9960 Sun Jan 16, 2011 1:15 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
