DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
3-core + earth into a ceiling rose
This topic originated from the How to page called Preparing cable for connection
Click here to return to the page called Preparing cable for connection.
  View previous topic :: View next topic
Author Message
lesterthejester
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 28, 2005 11:20 am    Post Subject:
Reply with quote Thanks
I need some advice, please. I have taken down my old light fitting (obviously without noting what wires went where) and I now have 2 cables hanging from the ceiling, each with 1 Red, 1 Blue, 1 Yellow and an Earth cable protruding.
The light I need to fit requires one Live & 1 Neutral feed, presumably from a \\\'Loop\\\', but I need to know how to run these wires through the loop.
Any suggestions?
Thanks,
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Mar 28, 2005 11:36 am    Post Subject:
Re: 3-core + earth into a ceiling rose
lesterthejester wrote:
Any suggestions?
depends how who wired it, wired it.
ideally you need a muti meter to establish what is what, or you need to gain access to the cables to see what they are connected to
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
theshogun
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 28, 2005 12:01 pm    Post Subject:
Do you have any more lights on the same switch?
If so check how this one is connected.
What cables do you have at the swicht that contrals this light?
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 28, 2005 5:09 pm    Post Subject:
Does (did) this light have two way switches? If so, look in both of them and note what goes where.
There are actually three distinct ways to wire two way light switches but one of them should not be used because you can end up with live on both sides of the bulb. Given what you've got in that rose, it's just possible that somebody used it.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
3 core and earth - all wires are live - WEIRD!? 25 1340 Wed Jun 22, 2005 3:07 pm
Single core and earth wiring 13 1020 Tue Aug 26, 2008 2:34 pm
3 core and earth flex - should I use both live cores? 16 1240 Sun Dec 16, 2007 8:41 pm
3 core and earth - but don't need the earth.. 8 600 Fri Nov 30, 2007 11:53 am
3 core and earth 6 580 Tue May 30, 2006 6:57 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
