Bosch Exxcel Washing Machine doesn't turn drum
6 Aug 2009
Warwickshire
My Bosch Exxcel washing machine which is just out of warranty has broken down yet again ! . :rolleyes:
There are no fault codes displayed. Basically the machine goes through programmes filling and emptying the machine but without turning the drum and without spinning ! I've checked the belt and it's OK.
Can anyone advise me whether this is likely to be just the motor brushes or whether it is likely to be something more serious ? If it could just be a problem with the brushes I'll take off the splash guard and have a look at them tonight...
It's certainly one of the symptoms of worn brushes on my machine (20+ year old Hotpoint 9524 800 DE LUXE - or something like that)
Thanks. My last machine was a Hotpoint which gave me sterling service.
To say I'm not impressed with my almost new Bosch breaking down for the second time is putting it mildly... :evil:
On the Hotpoint you knew when the brushes were worn because you'd get smoke and dust coming from the general area of the brushes. :p
Strange thing is that I'm not getting any error codes displayed.
I have none of that on the Bosch and I would have though it wasn't old enough to have worn the brushes out. Anyways, I'll have a look at the brushes when I eventually get home tonight ( might be interesting as I'm going for a few drinks with a departing work colleague straight after work... ) :LOL:
Anyone know the best place to buy new brushes if that is the problem ?
I'll post my findings here tomorrow.
I can't imagine the brushes being worn out after only a year (unless of course the machine runs 24-7).
Thanks for your reply Zipper - You're the Guru on these machines ! - I really appreciated your advice last time I had a problem.
I had a look at the brushes tonight and they are the problem ! The machine is probably closer to two years old. With two young kids my wife does tend to run it about three times per day.
I took out the brushes and they were worn right down. I cleaned them and the holders up and reassembled and the machine is working fine now - It looks like the cleaning did enough to restore enough pressure onto the commutator and everything to working order until the new brushes that I've ordered online for about £7 turn up.
I'm really pleased that I've saved having to call someone out - I can't afford it at the moment !
Thanks again for your help :cool:
post model number and fd number and we may be able to help more.
on door rim or rear plate usually unless a non german model?
Thanks for your reply. It's a Bosch Exxcel 1200 Express - I've solved the problem now so no need to post model number etc. It was a pretty generic problem which could occur on any Bosch appliance with carbon motor brushes.
