Banging Boiler Potterton
31 Mar 2005
hi i have a potterton puma 100e last couple of months it started banging and lock out would come on, press reset ok for a bit gradually got worse over the weeks, i have hot water (very hot water)CH problam pressure irratically jumps about while banging and grinding noise comes from top (might be boiling water) last couple of days CH working while switched off ne ideas
Chris
hi cheers a bit of wd40 on the switch works great for now ill look out for a new to fit ..
Sound advice cheers
fantastic! worked on mine too! THANK YOU! That was after I checked all the tracks on the PCB and the relays. Will teach me to search this site correctly in the future.
How long did your WD40 fix work for? Just seeing how long I can leave it until I buy/fit a new HW flow switch!
:D :D
