the base for the conservatory i have ordered is out by about 75mm across the diagnals, what problems am i likely to encounter when i fit the conservatory and more importantly ways around them?
The significance of the 75mm will vary slightly depending on the overall size of the base, but it seems a long way out to me. How big is the conservatory?
Is it a steel base or traditional foundation/brick/block?
