xtrafast 96 boiler
9 Sep 2010
discharge pipe running loses about 500ml a day have to keep refilling system have changed system pressure valve and ch pressure valve and hw pressure valve but still have aproblem as before any ideas
have u had ure heating on at all lately??possibly be the expansion vessel split or just needs re-charging,does the pressure rise when heating is on to 3bar??
I think that you mean the air valve!
It should be fairly obvious to you that an air valve should not emit water if pressed.
Obviously its failed and not absorbing any expansion hence your problem! Simple really.
Tony
anyone know where i can get a roof terminal for an extrafast 96 been told by
glowworm boiler obsolete and flue parts unobtainable but just spent £200
on boiler comes a bit hard to be told to buy a new one
You are not telling us much are you!
What have you spent £200 on?
Recharging a failed EXV may not last long if water was leaking from the air valve.
Who has told you you need a new vertical terminal and why?
Tony
Thats the problem speed reading particularly when its not properly written with correct grammar and capitals in the right places!
OK so you have CHANGED the EXV at £200 !
So whats the story about the flue?
Tony
whilst removing flue (roof terminal) bottom plastic sleeve was brittle and
a couple of holes appeared tried to get replacement no joy anyone know where available
