DIYnot
Local | Network
   DIYnot > Forums
Local | Network
trianco oil fired boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Runner251
from United Kingdom
PostPosted: Thu Sep 30, 2010 7:54 pm Reply with quote
Hi guys
Just wondered if any of you guys could help,I have trianco tro 12/14 boiler and just fired it up to check everythings ok for winter,but alas no,after 10>15 mins hot water & steam came out of the pipe over the expansion tank so I turned it off.Sus thermostst or may be oil cut off valve can you help. Cheers
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 655 times
PostPosted: Thu Sep 30, 2010 8:27 pm Reply with quote
Stat may be dodgy, could also be that your circulating pump has broken
Back to top
 Alert Moderators
Runner251
from United Kingdom
PostPosted: Fri Oct 01, 2010 2:34 pm Reply with quote
Cheers muggles for reply. Had new pump fitted a couple month ago and power flush so may be you are right. would you happen to know what stat would do the job, also where I could get one. Cheers again icon_wink.gif
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 948 times
PostPosted: Fri Oct 01, 2010 6:34 pm Reply with quote
The original was a Teddington TBB these are no longer made, but if you take the old one to a spare part merchant they should be able to repolace it with a Ranco C26 with a suitable phial icon_wink.gif
Back to top
 Alert Moderators
Runner251
from United Kingdom
PostPosted: Sat Oct 02, 2010 10:36 am Reply with quote
Cheers boilerman2 for your reply,I will remove it and go stat hunting.Thanks again guys for your help. icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Trianco 12 / 14 Oil Fired Boiler Problem! 9 620 Sat Jan 16, 2010 4:09 pm
Trianco Oil Fired Boiler 38 5740 Fri Nov 20, 2009 6:17 pm
Trianco TRO 15/19 oil fired boiler water leak 2 620 Tue Oct 20, 2009 7:21 pm
trianco eurostar 100/125 condensing oil fired boiler 15 2560 Mon Jan 18, 2010 11:34 am
Water seeping out of bottom of Trianco Oil fired boiler 11 240 Tue May 24, 2011 7:28 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
